Hoe moet ik nu die Z21 -detector X16 gaan instellen.
Ik heb geen win-pc, enkel een Raspberry-PI en ook geen Z21 App. Ook geen multiMAUS :.volgens handleiding : Configuration via button.
Connect the Z21®- Detector X16 to the R-BUS and supply track voltage of the control panel to the track
inputs P and N of the Z21®- Detector X16.
The blue "Status" LED flashes briefly and does not light up permanently until you have connected the
Z21®- Detector X16 to the R-BUS. Press the programming button on the Z21®- detector X16 for at least 1
second; the white program LED starts to flash. Activate a magnet article with the address of your choice
within the next minute. The magnet article can be activated using the Z21® App or another input device
such as the multiMAUS. The address has been accepted by the Z21®- detector X16 after the white program
LED has stopped flashing.
Wat bedoelen ze met een “magnet article” en waar moet ik dat dan aansluiten?
